myunes
Dec 15, 2019Tutor
RAX120
Hi Everyone, New here. I've been trying to learn as much as I can about the RAX-120 and why it keeps losing it's network connection. I have been on the phone with Netgear support and escalated to t...
- Jan 01, 2020For what it’s worth... after 7 phone calls, three case numbers and three times that the escalated support was supposed to call me but didn’t, on the advice of an IT friend I bought the new AMPLIFI alien router.
Can I tell you what a different experience it is. I followed the instructions and guess what? It just works. The on screen info is great. The app is simple and allowed me to do a firmware update. It connected my wireless (22 connections) at 840 MBs and my 31 Ethernet items (2 gigabit switches) without a problem. To add range I added a second one on the Ethernet backbone and now my whole yard is getting 800+ MBs.
I didn’t need to call for support. Didn’t need to reinstall firmware. Didn’t need to change radio channels and install a monitor program.
I’m done with Netgear. The router and mesh access point are getting returned. This is how it is supposed to work.
Best decision I made was to cut bait!!
marinerbcfc
Dec 15, 2019Tutor
Hi there,
i am running the same firmware , connectivity solid with 18 clients , initially when i received the router i did update the firmware
to that version, reset the router to factory reset " press the reset button for about 5 seconds "
called my ISP to reset the bridged modem to factory setup, re estblished it to bridge bridge mode again.
have no issues . hope that help
