arthurbeg
May 13, 2020Aspirant
RAX120
Just bought a brand new rax120 from bestbuy previously had the rax80 both routers seem to cap out at 300mbps when i have gig speeds. tried everything and nothing helped. are these routers just horribl...
arthurbeg
it’s connected to a cm1200 modem, i’ve tried to run with it’s cat5e wire, cat6 wire and cat7 wires all with the same results. wired connection is the same. wired straight from the modem gets me the speeds i need. it’s on the latest version 122 i have tried downgrading to 118 and another one i can’t remember. got those numbers straight out the box for 2 days before messing with it. i’ve ran on fast.com, speedtest.net and cox’s speedtest with the same results
arthurbeg
I’ve ran the test on 4 different iphones and 3 different laptops. 3 of the iphone have ax and 1 of the laptops has ax as well
