Loronew
Oct 20, 2020Aspirant
RAX120
My RAX120 drops my fire sticks but maintains a connection to my iPhone, iPad and other 20 devices. If I do a factory reset everything works again but about 2 weeks later the same thing occurs. Can an...
Loronew
Oct 23, 2020Aspirant
No. I figured since the problem is temporarily resolved after doing a hard reset of the router that it was a software issue with the Netgear Router. I have 5 fire sticks that all stop working at the same time until I reset the router then they work perfectly again
Christian_R
Oct 23, 2020NETGEAR Employee Retired
Lorenew,
You may also check to see if your device is due for a firmware update.
Christian
- LoronewOct 23, 2020AspirantFirmware is up to date
- NewfiedroolOct 24, 2020Virtuoso
I've a fire stick the 4K version and no issues. Have you by any chance unlocked these devices.
Does your logs show anything as in repeated requests of DHCP for the devices?
- LoronewOct 24, 2020AspirantNo. I have HULU, Netflix, Disney, Crunchyroll, CBS & WatchTV.
