thehypnootoad
Mar 03, 2021Luminary
Rax120
Hello again Im at the end of my tether with this rax 120 this is the second one now after getting rma. It is doing the pretty much same thing as first one did. I switched back to my d7000 v1 and used...
michaelkenward
Mar 04, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
