thehypnootoad
Mar 10, 2021Luminary
Rax120
What firmware for rax120 is stable please.
Mar 10, 2021Guru - Experienced User
For the vast majority, its the latest firmware. there's always a few that have issues with specific firmwares but the majority do fine on the current versions.
You can always make a backup and install the latest version. If it doesn't work well for you, downgrade the firmware, factory reset, and then install the backup.
- thehypnootoadMar 10, 2021LuminaryFinding .16 issues with connection dropping and dchp connections. .136 seems better but traffic monitor won't work which recent fixes also can't connect my smart life wifi bulbs and smart plugs devices with this router.
