thehypnootoad
Mar 15, 2021Luminary
Rax120
Does anyone actually have a rax120 that works? Is there going to be a firmware update that actually fixes this piece of crap? Is anyone else fed up of not knowing whats going on with this thing? Ar...
michaelkenward
Mar 16, 2021Guru - Experienced User
Probably not here.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
- thehypnootoadMar 16, 2021LuminaryThank you hope to get answer.
