thehypnootoad
Mar 15, 2021Luminary
Rax120
Does anyone actually have a rax120 that works? Is there going to be a firmware update that actually fixes this piece of crap? Is anyone else fed up of not knowing whats going on with this thing? Ar...
Chichizola
Mar 16, 2021Star
Regardless of where you post this, Nighthalk RAX120 is in deed a piece of crap and their support is even worst. I have been fighting with NetGear to exchange it for two weeks. they gave me two RMAs, and told me to expect an email to select how I wanted to exchange it, Emails never came.
From the numerous posts, I doubt the replacement will work. I much rather get a refund at this point.
thehypnootoad
Mar 17, 2021Luminary
Finally someone that agrees that this router is not fit for purpose . It also seems Netgear aren't interested, I have already had 1 rma done but it turned out to be exactly the same faults. Im starting to wonder if this is the reason v2 came out as they know v1 is a failure and should have been offered the v2 as rma replacements. Can someone from Netgear comment on this. As more than happy to replace and see if this is the issue.
- ChichizolaMar 17, 2021Star
The devise is garbage, I am trying to return it there are many other brands that will do a much better job. I am extremly disapointed by the brand and their support.
