Cal_mack
Dec 08, 2021Aspirant
Rax120
Hello, I’m having a big issue with my PlayStation 5 which is connected via Ethernet cable. More often than not it disconnects my lab cable and connects it straight back afterwards, it will do this lot...
Cal_mack
So the PlayStation will say lan cable disconnected, lan cable connected like it just drops the connection for a second then connects again. Sony have said it is a firewall setting within the router? I’m not too clued up with this stuff.
Thanks for your help!
Dec 08, 2021Guru - Experienced User
What modem/gateway is it connected to?
Have you tried replacing the ethernet cable?
