thehypnootoad
Nov 15, 2022Luminary
Rax120
When I try change ipv6 dns either to goigles or cloudflares it works but all the web pages seem to load alot slower tried a web ipv6 tester says all is good any suggestions thanks Ashley.
- Nov 15, 2022
How is the IPv6 configured on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Are you using a wired or wireless connection?
Happens on all devices?
Might try a factory reset and setup from scratch. Leave debug page features disabled.
Nov 15, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- thehypnootoadNov 15, 2022LuminaryHi tried the turning off and on but still slow pages, the ipv6 is on pppoe but tried 6-4 and auto detect. Iam on the latest firmware on the rax 120v1 also been into debug page and allowed ping internal external ipv6.
- FURRYe38Nov 15, 2022Guru - Experienced User
- thehypnootoadNov 15, 2022LuminarySorry missed that out its a huwei hg612 modem unlocked - netgear rax120v1 and its bt the auto dns for ipv6 works fine its running on ipv6 pppoe will upload photo when get home i think the cable is cat5e will check though.
