thehypnootoad
Nov 15, 2022Luminary
Rax120
When I try change ipv6 dns either to goigles or cloudflares it works but all the web pages seem to load alot slower tried a web ipv6 tester says all is good any suggestions thanks Ashley.
- Nov 15, 2022
How is the IPv6 configured on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Are you using a wired or wireless connection?
Happens on all devices?
Might try a factory reset and setup from scratch. Leave debug page features disabled.
thehypnootoad
Hi tried the turning off and on but still slow pages, the ipv6 is on pppoe but tried 6-4 and auto detect. Iam on the latest firmware on the rax 120v1 also been into debug page and allowed ping internal external ipv6.
Nov 15, 2022Guru - Experienced User
- thehypnootoadNov 15, 2022LuminarySorry missed that out its a huwei hg612 modem unlocked - netgear rax120v1 and its bt the auto dns for ipv6 works fine its running on ipv6 pppoe will upload photo when get home i think the cable is cat5e will check though.
- FURRYe38Nov 15, 2022Guru - Experienced User
I presume the modem is in bridge mode?
Wonder if you put the modem back in router mode and use it's DMZ for the RAX if this would change the behavior...
CAT6 would be recommended.- thehypnootoadNov 15, 2022Luminary
