anurag_ccna
Mar 18, 2023Aspirant
RAX120
I have RAX 120 with 500mbps internet bandwidth and a 2 TB USB connected to usb1. Its shared on network with everyone able to access it as a network drive by my samsung tv is acting weird with this. I...
Retired_Member
Mar 19, 2023It's a fw issue, Netgear is working on a fix.
- anurag_ccnaMar 19, 2023AspirantThank you Catalin26 for replying. Is there any temporary workaround for this issue or if that bug is public facing? Wondering how we can track progress on that issue. Thanks
- Retired_MemberMar 19, 2023
There is no temporary workaround, all we can do is wait and hope that the next fw will have a fix for this problem.
I had no other choice, had to buy an android media player so I can watch my movies.- plemansMar 19, 2023Guru - Experienced User
If you regularly watch movies off a plugged in USB device, i'd actually look at upgrading.
Moving from a basic dlna server to a dedicated one makes a big difference. An old NUC will run plex/jelly fin fine and you'll be surprised at home much easier it is to use and stream from.
I made the switch years ago and haven't looked back.
