FelizComidas
Apr 07, 2020Guide
RAX12000 WiFi Speed Slowdowns Daily
Hi All - In October 2019, I bought the CM1200 modem and the RAX120 router. The modem has been solid, but I have had speed slowdown issues since day 1 with the router, requiring a reboot every 12-24 h...
FelizComidas
Apr 07, 2020Guide
Subject Should be RAX120..whoops!
- plemansApr 08, 2020Guru - Experienced User
Are you running it with wan link aggregation? If so, disable this. its been unstable since day 1.
what firmware is on the router?
- FelizComidasApr 08, 2020GuideI am not running link aggregation.
Currently on firmware .118. I tried going back to .114, but had some issue (have always had the issue).
I originally went from .114 to .118 when router did a reset of all settings on .114 and would reset / lose all settings every time it rebooted (which stopped when updated to .118).- plemansApr 08, 2020Guru - Experienced User
there's a beta firmware for the RAX120 that might help.
You'd need to private message Christian_R for access to it.
