FelizComidas
Apr 07, 2020Guide
RAX12000 WiFi Speed Slowdowns Daily
Hi All - In October 2019, I bought the CM1200 modem and the RAX120 router. The modem has been solid, but I have had speed slowdown issues since day 1 with the router, requiring a reboot every 12-24 h...
Apr 08, 2020Guru - Experienced User
Are you running it with wan link aggregation? If so, disable this. its been unstable since day 1.
what firmware is on the router?
FelizComidas
Apr 08, 2020Guide
I am not running link aggregation.
Currently on firmware .118. I tried going back to .114, but had some issue (have always had the issue).
I originally went from .114 to .118 when router did a reset of all settings on .114 and would reset / lose all settings every time it rebooted (which stopped when updated to .118).
- plemansApr 08, 2020Guru - Experienced User
there's a beta firmware for the RAX120 that might help.
You'd need to private message Christian_R for access to it.
- FelizComidasApr 12, 2020Guide
Thanks. I will reach out to see if that is a potential solution.
Any other thoughts from anyone in the mean time would be helpful.
- Brian_COMay 17, 2020Aspirant
Did you get an answer to this question. I'm having the exact same issue. If I reboot, speeds are great for 12 to 24 hours. Reading other posts we aren't the only ones in this situation. Someone mentioned it might be released to ip lease renewal that seems to be causing it, I haven't checked yet if I can increase the lease time so that I have to reboot less often.
