alldren
Jul 17, 2023Aspirant
RAX120v2 - Can not add new devices
I have a very annoying problem. I can not add new devices to the wifi after the first initial setup, about 1 to 7 days. I've tried everything that doesn't involve hard resetting, but unfortunately ha...
- Jul 19, 2023
alldren wrote:
Thank you for the assistance. I might need a little more help, I'm not really that good with networking stuff.
In that case, I'd go for the simplest option. You will find that Netgear recommends "bridge mode" as the preferred option.
How to fix issues with Double NAT | Answer | NETGEAR Support
Talk of some things like an unexplained "DMZ mode" is not for the faint hearted.
Stick with this bit:
https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-routerThat is the first of the three options you were presented. Bridge mode is a one off fix that eliminates all the other witchcraft. Use that and you can ignore the rest.
I'd start here and look at the various hits.
bgw320-505 bridge mode - Google Search
You may even find a useful video that takes you through the process.
michaelkenward
Jul 18, 2023Guru - Experienced User
alldren wrote:
Can somebody please tell me whats going on with my router?
I have my suspicions, but need more information.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
alldren
Jul 18, 2023Aspirant
bgw320-505Thank you for your response.
My firmware is: v1.2.8.40
It is running off a modem/router from ATT Uverse. BGW320-505
Originally I disabled the wifi on the ATT router, but I re-enabled it because I got tired of hard resetting my Nighthawk router. Now I just add any new device on the ATT router.
- FURRYe38Jul 18, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-modeTry option #2 first.
What is the first 3 characters of the routers serial number?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- alldrenJul 19, 2023Aspirant
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-routerFor step 2:
...disable ALL wifi radios on the modem
I know how to disable all my wifi radios on the modem.
... configure the modems DMZ/ExposedHost:
I cant find this option in my ATT modem router settings, but I know where it is on the NG's router settings.
...IP Pass-Through for the IP address the NG router gets from the modem
I did find this on my ATT modem.
Should I do the DMZ on my NG settings or IP passthrough on my ATT modem or do both?
6JY
Thank you again for the help.
- michaelkenwardJul 19, 2023Guru - Experienced User
