alldren
Jul 17, 2023Aspirant
RAX120v2 - Can not add new devices
I have a very annoying problem. I can not add new devices to the wifi after the first initial setup, about 1 to 7 days. I've tried everything that doesn't involve hard resetting, but unfortunately ha...
- Jul 19, 2023
alldren wrote:
Thank you for the assistance. I might need a little more help, I'm not really that good with networking stuff.
In that case, I'd go for the simplest option. You will find that Netgear recommends "bridge mode" as the preferred option.
How to fix issues with Double NAT | Answer | NETGEAR Support
Talk of some things like an unexplained "DMZ mode" is not for the faint hearted.
Stick with this bit:
https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-routerThat is the first of the three options you were presented. Bridge mode is a one off fix that eliminates all the other witchcraft. Use that and you can ignore the rest.
I'd start here and look at the various hits.
bgw320-505 bridge mode - Google Search
You may even find a useful video that takes you through the process.
alldren
Jul 19, 2023Aspirant
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
For step 2:
...disable ALL wifi radios on the modem
I know how to disable all my wifi radios on the modem.
... configure the modems DMZ/ExposedHost:
I cant find this option in my ATT modem router settings, but I know where it is on the NG's router settings.
...IP Pass-Through for the IP address the NG router gets from the modem
I did find this on my ATT modem.
Should I do the DMZ on my NG settings or IP passthrough on my ATT modem or do both?
What is the first 3 characters of the routers serial number?
6JY
Thank you again for the help.
michaelkenward
Jul 19, 2023Guru - Experienced User
