KoinFlipper
Dec 23, 2022Tutor
RAX120V2 cannot access router after Factory Reset
RAX120V2 router Did factory reset and now cannot access router to setup. When I go to www.routerlogin.net it redirects to 192.168.1.1/BRS_index.htm Says Internet detected. Cannot get past Admin ...
Dec 25, 2022Guru - Experienced User
Try the reset 1 more time. Push and hold reset for 7-15 seconds.
Then reattempt the setup.
Usually when the next is grayed out, you didn't meet the minimum requirements for something.
Make sure the password you setup has at least 10 characters
1 special character
1 upper case
1 lower case
1 number.
