blackjackx1031's avatar
Aug 25, 2022
RAX120v2 Constantly rebooting
RAX120v2 is constantly rebooting. There are a number of topics on this but all are closed.  I have tried factory reset, i have tried keeping the fan on through debug mode. Maybe just need the beta firmware? My frirmware is V 1.2.3.28. I bought the router in april of this year. Router is an a large open space with nothing blocking it
1 Reply
  • FURRYe38's avatar
    How often is the router rebooting?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What devices do you have all connected to the router?
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Is WMM enabled on the router?
    Contact the forum moderator aboutr the beta FW thats available:
    DarrenM
