Simon95132
Dec 25, 2021Aspirant
RAX120v2 Drops wifi and lan connection
I’ve been noticing the router out of the blue drops all wifi and lan connections and in about 1minute come back online. Both the guest and non guest wifi go away. The problem seemed to start after a c...
Simon95132
Dec 26, 2021Aspirant
I’m ahead of you on that one. I have the modem setup in dmz mode. The wifi is disabled on the modem or off. The nat is open. I am using ipv6 instead of ipv4. It’s been working well but not so much in the last month.
Simon95132
Lease time is 10minutes. Seems pretty short
- Simon95132Dec 26, 2021AspirantI was reading some posts on the pace modem in dmz mode. Att sets their lease time to 10minutes so that explains what I am seeing. It seems att prefer to keep this setting on their end. I’m not believing this is my problem.
I’m baffled. What else can I do to better diagnose the problem when it happens?- plemansDec 26, 2021Guru - Experienced User
If you connect the orbi to the att device in access point mode, do you still get the issue?
- Simon95132Dec 26, 2021AspirantRunning AP is not an option for me. Has it solved someone else’s similar problem to mine? My wifi drops connection and so does lan. It’s doesn’t smell like ISP or pace issue…
