EpicEnigma
Jan 11, 2023Guide
RAX120v2 keeps dropping devices ofthe Wifi hardwired devices remain good. Firmware V1.2.8.40
So my current firmware is V1.2.8.40 I have been having issues with all my wifi devices dropping. Anyone have a fix for this? I don't know why I suckered my self into another Netgear product. I am rea...
- Jan 11, 2023
I would like to try this beta firmware that everyone is raving about, again current firmware on it is 1.2.8.40
Jan 11, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What's the 1st 3 characters seen on the router serial number please.
What all devices do you have connected?
Does the any of the top LEDs turn AMBER when this happens?
Does look cool though...
EpicEnigma
Jan 11, 2023Guide
Firmware and model listed, I am using SPectrums new cable modem, it does not have wifi built into it. I am using a good cat6 wire. The wire and modem are meaningless because the lan connection never loses connection, its only the wifi that loses connection.
- EpicEnigmaJan 11, 2023Guide
- FURRYe38Jan 11, 2023Guru - Experienced User
There a model of Spectrums new modem? Not everyone may know that there is a new modem out.- EpicEnigmaJan 11, 2023Guide
Cell phones, Google displays, everything wifi disconnects. No amber lights. I can't even guarantee that the serial is correct because the factory sticker ( which does not look tampered with at all) the wifi info don't match the factory reset info in the router.
