xrsenal
Mar 09, 2022Aspirant
RAX120v2 LAN & WiFi Disconnects
Hello I own the RAX120V2. I factory resets after performing a manual firmware upgrade multiple times. Wether it’s every hour or every 2-3 hours, ALL wifi disconnects (wifi band disappears) and ...
Mar 09, 2022Guru - Experienced User
What devices do you have connected?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Are there any LED inidications seen when this happens on the router?
- xrsenalMar 09, 2022AspirantI’m not answering all these details.
This is clearly an issue with the firmware. I’ve seen tons of posts about this.
Every other router works fine.
XR1000,R2, all asus routers….
What is the firmware fix for this
