totallyripped
Jan 30, 2024Follower
RAX120v2 Loses Internet Connectivity
I often encounter internet connectivity problems with my RAX120v2, which happen throughout the day and night. While the wireless connection remains functional, both wired and wireless devices lose in...
Jan 30, 2024Guru - Experienced User
Has Armor ever been enabled or is it enabled on the RAX120v2?
How often does the RAX encounter this issue?
Does the top INTERNET LED turn AMBER when this happens?
Are you using the Yellow WAN port or the multi-gig port for the connection to your modem/ONT?
What channel configurations are currently set on the router?
totallyripped wrote:
I often encounter internet connectivity problems with my RAX120v2, which happen throughout the day and night. While the wireless connection remains functional, both wired and wireless devices lose internet access. To fix this issue, I have to physically reboot the router, after which everything returns to normal operation. The Router is using firmware version V1.2.9.52.
