b1080
Sep 22, 2026Aspirant
RAX120v2 Newly Disconnecting in Bridge Mode
I picked up a Nighthawk AX12 RAX120v2 to use for a Bridge. I have a few computers in the living room on LAN and I need them to be on Wifi with the main modem/router my ISP provided in another room fo...
b1080
Nope, no device via wifi to the RAX120v2 in bridge mode.
The apartment setup is approximately:
Wired devices connected to the RAX120v2 in bridge mode
* 1 Linux desktop
* 4 Windows mini-pcs (1 is the TV PC, the other 3 are a mini-lab project)
* 1 NAS (Linux)
Wifi devices connecting to the ISP router/modem combo
* the RAX120v2 in bridge mode
* 1 Chromebook
* 2 Macbooks
* 1 Windows Laptop
* 2 Android phones
We've got one Software Engineer and one Graphic Designer who work-from-home so its a bunch of stuff for personal and professional needs.
Whenever the issue happens, all the wired devices lose internet and none of the other wifi devices lose internet. Rebooting the bridge-router typically resolves it, but sometimes is takes a second reboot cycle for it to come back.
Sep 23, 2026Guru - Experienced User
b1080 wrote:Whenever the issue happens, all the wired devices lose internet and none of the other wifi devices lose internet. Rebooting the bridge-router typically resolves it, but sometimes is takes a second reboot cycle for it to come back.
When the problem happens, can you access the RAX120v2 admin interface from one of the wireless devices?
b1080 wrote:Wired devices connected to the RAX120v2 in bridge mode
* 1 Linux desktop
* 1 NAS (Linux)
Are you using all 6 ethernet ports on the RAX120v2? (including the WAN port)?
Or is there also a switch connected to one of the ports?
- b1080Sep 24, 2026Aspirant
So far I haven't been able to check the access to the dashboard. Most of the time, I'm late to an online call etc. where I need to just reboot it and get myself going. I'll be trying this next time it happens.
In terms of the ports (good question)
* Nothing in the WAN port
* The NAS is in the one higher speed port
* The Linux desktop is in a LAN port
* The TV PC is in a LAN port
* A switch is plugged into a LAN port, which has the 3 mini PCs in the lab rack plugged into it.
* There is 1 empty LAN port.- b1080Sep 24, 2026Aspirant
Just had it happen, and no I cannot access the Admin Panel while its occurring.
- StephenBSep 25, 2026Guru - Experienced User
b1080 wrote:
* I could not ping devices behind it.
* I could not connect to get into the admin panel on the RAX
* On my linux machine I effectively got 2 messages
1.) Limited Connectivity. Connected to a network but unable to reach internet.
2.) IP Configuration was unavailable. (this seems like the one that tells us something)This is all consistent with the wifi connection between the RAX and the router dropping.
Though (2) is a bit odd, since the DHCP lease to the router should have resulted in keeping the IP address info.
You could try reserving IP addresses for the RAX and one of the wired clients (or even assigning temporary static IP addresses) - then see if you can reach the RAX admin interface from that wired client after the problem recurs. That might give you a bit more info on what is happening with the RAX.
