bjc_27
Oct 09, 2021Initiate
RAX120v2 Randomly Reboots Only While Streaming Over Wi-Fi
I’ve had my router for a few months now, but this issue has been happening since the beginning. Everything works perfectly with the Wi-Fi except for when someone starts to stream something. I have abo...
Oct 11, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Smart Connect and MIMO enabled?
Try turning OFF most of the wifi devices accept for the streaming device. Does the problem still happen?
Try disabling Smart Connect and if it's an option, disable AX mode on the router and see if the problem continues.
bjc_27
Feb 27, 2022Initiate
Firmware version: V1.2.3.28
Channels: 2.4Ghz is on channel 1. 5Ghz is on channel 48.
Any WiFi neighbors nearby? Yup. A lot. My WiFi is detecting 39 Wifi neighbors around me.
Smart Connect and MIMO are enabled.
Isn't AX mode the point of having a WiFi 6 router? How would turning that off help?
