djdoh88
Dec 05, 2022Aspirant
RAX120v2 Rebooting Issue
Hi, I'm currently using Nighthawk AX12 RAX120v2 Router Firmware Version V1.2.8.40 This has been a pretty horrible user experience for the past ~5 months that I've been using this router. Fro...
Dec 05, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the first 3 characters of the routers serial number please?
- djdoh88Dec 05, 2022Aspirant
Hi
Thanks for the reply!
ISP is Xfinity. I have a hard time finding out the mfr/model number for the ISP provided modem but it's one of those white xfi gateway modems. Confirming that I am using a good LAN cable (Cat 8 in fact :D). Router is in Access Point mode right now.First three letters of the serial number for the RAX120v2 I have are 6JY.
- FURRYe38Dec 05, 2022Guru - Experienced User
So if the RAX is in AP mode, your ISP modem would have a built in router or you have a router in between the modem and the RAX. AP mode requires a router and DHCP services.
Can't find a brand name and model of the ISP modem on the case anywhere?
To properly test the RAX, the RAX should be in router mode to check this beta...
Hmm got it. Yes I was using RAX as AP and the modem that the ISP gave had router function (I could've used it as a wireless router alone as well but I wanted to see if there would be performance benefits to using RAX120v2). No boxes I can find with the modem. But they are these XFI ADVANCED GATEWAY (XB7) (CGM4331COM or TG4482A) found here https://www.xfinity.com/support/articles/broadband-gateways-userguides.
I was using AP mode because another minor bug I faced with an accessory product but I guess I can try router mode again!
