HowardCoy
Oct 27, 2023Aspirant
RAX120v2 slow after tech support changes
I had the reboot issues with my router. Got the paid tech support. I’ve been on the phone with the very difficult to understand people almost daily. I no longer get the reboot issues but the router in...
Oct 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. CAT6A STP if your using the MG port on the RAX Router.
Are you using the Multi Gig port for the internet connection or the Yellow Internet port?
Are you speed testing with a ethernet connected PC or wireless device? Ethernet is preferred for speed testing and accuracy.
- HowardCoyOct 27, 2023AspirantMy firmware is 1.2.9.52. The modem I use is one I purchased and used with my previous router. It is an Arris SB8200. I use CAT6 cable connected to the yellow internet port.
- FURRYe38Oct 27, 2023Guru - Experienced User
Can you explain what NG support did to the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.- HowardCoyOct 27, 2023AspirantCan you explain what NG support did to the router?
I wish I could. They take over and zip through their changes and I have been unable to keep up. This has happened about every other day for the past 4 months!
I know Ethernet is preferred but seems counterintuitive since all my connections are wireless.
I have disabled everything except the Armor. I’m willing to try that.
Multiple times. Every tech wants me to do that every time I call them back. Even changed out all the cables.
Yep did everything in that order. Again multiple times.
