PhilBates
Aug 11, 2023Aspirant
RAX120v2 Wifi signal keeps dropping
Hi, my wifi signal keeps dropping almost every day and requires constant rebooting. The problem is not with the modem. Please help. Thanks, Phil
PhilBates
Just FYI, the Nighthawk app says I am updated with the latest firmware.
Provider: Spectrum
No wifi nearby
Devices: 5 computers, Eufy 2C security system -2 base stations, two iPhones, one printer, LG TV. Apple TV.
Aug 11, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the first 3 characters of the routers serial number?
- PhilBatesAug 11, 2023Aspirant
I don't see a manufacturer name or model number. What I do see is this:
ES2251
DOCSIS 3.1 eMTA
Made in Philippines
SD10
There is also a CM MAC number and a MTA MAC number
Does that help?
- FURRYe38Aug 12, 2023Guru - Experienced User
What is the first 3 characters of the RAX120 router serial number?
- PhilBatesAug 12, 2023Aspirant
//What is the first 3 characters of the RAX120 router serial number?//
The first three characters are: 6JY
The modem has only one ethernet port and two voice ports. I don't know if it does wifi. I picked it up new last week from the provider (Spectrum).
The firmware is up to date according to the product support pages.
Thank you so much for helping me!
Phil
