Cnote22's avatar
Cnote22
Initiate
Sep 09, 2020
RAX15 AX1800 bottlenecks my internet speed 1gb from modem drops to 150mb when router is added.
Hi everyone,  I just had my optimum service installed. I am paying for their 1gb down.   I am using an Aris SB8200 DOCIS 3.1 modem.   When my computer is plugged in directly to the modem, speed ...
  • plemans's avatar
    Sep 09, 2020
    do this.
    1. factory reset the router.
    2. during setup make sure not to enable: qos, parental controls, traffic monitoring, or access controls.
    Those services drop speeds because they have to inspect the traffic and it puts a burden on the cpu to do so.
    you can try just disabling them first and rebooting the router. But in rare occasions I've read of those settings being retained even through a reboot which is why i recommend the reset option.
