Cnote22
Sep 09, 2020Initiate
RAX15 AX1800 bottlenecks my internet speed 1gb from modem drops to 150mb when router is added.
Hi everyone, I just had my optimum service installed. I am paying for their 1gb down. I am using an Aris SB8200 DOCIS 3.1 modem. When my computer is plugged in directly to the modem, speed ...
- Sep 09, 2020
do this.
1. factory reset the router.
2. during setup make sure not to enable: qos, parental controls, traffic monitoring, or access controls.
Those services drop speeds because they have to inspect the traffic and it puts a burden on the cpu to do so.
you can try just disabling them first and rebooting the router. But in rare occasions I've read of those settings being retained even through a reboot which is why i recommend the reset option.
Sep 09, 2020Guru - Experienced User
do this.
Cnote22
Sep 10, 2020Initiate
Thanks for taking the time to respond!
It looks like the factory reset did the trick. I appreciate the help. Was hoping to avoid that so I wouldn't have to redo all of my port forwarding. I am now seeing speed between 850mb/s to 900mb/s as expected.
It's unfortunate that the hardware isnt sufficient to run the stock features of the software.
Thanks again!
