g3auto
Jun 11, 2021Tutor
RAX15 AX1800 error CDIL-API-FAIL when trying to access the device list
I have an rax15 AX1800 and am getting CDIL-API-FAIL when try to access the device manager. I am accessing it from my local connection and getting the error on both my iPad and iPhone. Have tried rei...
g3auto
Jun 11, 2021Tutor
There is no modem, it is connected directly to the isp wire. I have tried the reboot multiple times and there is no way I'm go8ng to do a factory reset, spent to much time configuring the router, static IPs, etc. this is only happening within the nighthawk app and not when I connect with a browser.
Jun 12, 2021Guru - Experienced User
Then your option is to wait it out and see if an app update or firmware change fixes it.
- Wolverine3Jun 26, 2021Aspirant
I also have an RAX15 (not found in the model drop-down list for this reply by the way) with the same firmware version that is suddenly not allowing me to go into the Device Manager screen. I, instead, receive an error message that states, "Sorry, the action was failed. Please try again. (code: CDIL-API-FAIL), with an OK button. Standard reboots have been unsuccessful so I'll go through the pain of a complete reset. I just wanted to post this so the Netgear engineers have another customer-experienced failure datapoint.
