mpe2903
Dec 03, 2020Aspirant
RAX15 AX1800 Internet speed only peaks at 300mbps
Hi, I have a similar issue as described here: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX15-AX1800-bottlenecks-my-internet-speed-1gb-from-modem-drops/m-p/1973866#M1269...
Dec 03, 2020Guru - Experienced User
You have an RAX15.
What firmware is on it?
What modem/gateway are you connected to?
How are you testing? Wired? wireless?
What website are you testing on?
- mpe2903Dec 03, 2020Aspirant
My Router: Nighthawk RAX15 Firmware Version V1.0.2.64_2.0.42Arris SB8200 modem. 980mbps down direct connection.
wired and wireless with multiple devices
xfinity speed test, speedtest.net
- plemansDec 03, 2020Guru - Experienced User
What port on the SB8200 are you connected to?
Make sure its port 1 and nothing else is in port 2.
have you tried a different cable between modem/router?
After you reset the RAX15, did you ever speedtest it with it running in default configuration? without changing anything in settings?
I'd try this.
- Port 1 on the SB8200
- Swapped cables
- Speedtest after factory reset
Same result
