mpe2903
Dec 03, 2020Aspirant
RAX15 AX1800 Internet speed only peaks at 300mbps
Hi, I have a similar issue as described here: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX15-AX1800-bottlenecks-my-internet-speed-1gb-from-modem-drops/m-p/1973866#M1269...
Dec 03, 2020Guru - Experienced User
What port on the SB8200 are you connected to?
Make sure its port 1 and nothing else is in port 2.
have you tried a different cable between modem/router?
After you reset the RAX15, did you ever speedtest it with it running in default configuration? without changing anything in settings?
I'd try this.
I usually don't say this (and not sure if rax15 has this) but have you went into the dynamic qos and manually set your speed?
