AGoodUsername
Jul 11, 2020Aspirant
RAX15 occasionally losing internet when USB device connected
(The model is RAX15: https://www.netgear.com/support/product/rax15.aspx; I'm not sure why it isn't showing up in the "Model" list above. Also, I am running firmware version V1.0.1.58_2.0.31, which is...
Christian_R
Jul 16, 2020NETGEAR Employee Retired
Hi AGoodUsername,
If you recently purchased the device, I would recommend contacting our support team using the link below.
https://www.netgear.com/support/default.aspx
Christian
