pal333
Apr 22, 2020Follower
RAX15 Unstable Wifi
I have bought the RAX15 and replaced with very old router. At the firstime with factory firmware...it showed better 2.4ghz wifi speed, but coverage was not great and 5ghz was unstable. (2.4ghz wifi...
Christian_R
Apr 24, 2020NETGEAR Employee Retired
Hello pal333,
If you recently purchased the router please note that your device is provided with 90 days of complimentary support and you may access it using the link below. Furthermore, may you provide us with the firmware version your router is currently on. You may try changing the WiFi channel on your 2.4ghz band to see if that would help.
https://www.netgear.com/support/default.aspx
Christian
