procflora
Mar 30, 2021Aspirant
RAX15 UPnP port forwards not working
Model: RAX15
Firmware: V1.0.2.82_2.0.52
Hi there, my router doesn't seem to be forwarding the ports as configured by an appliance on my LAN as displayed in the UPnP portmap. The portmap list looks correct, however connections to the router's public IP on that port do not work. If I manually add the same port forwarding settings in the Port Forwarding section of the settings page the same test works fine. I am really scratching my head as to why this isn't working. Really appreciate the help!
Portmap:
UPnP Result:
UPnP Result
Manual forward:
Manual Result:
Manual Result
- procfloraAspirant
- Christian_RNETGEAR Employee Retired
Hi procflora,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
