IzzyWorks
Oct 20, 2021Tutor
RAX20 - Intermittent-DNS lookup
Hello! I recently set up the RAX20 (AX1800) and I have been getting good speed, low and stable ping, and stable continuous transfer rates with the router. Overall very happy and see about 160 to 200 ...
Oct 20, 2021Guru - Experienced User
what modem/gateway is it connected to?
do you have IPv6 enabled? Have you tried enabling it?
Another thing is you can try googles dns at 8.8.8.8 or 8.8.4.4
- IzzyWorksOct 20, 2021Tutor
The modem is Technicolor TC4350,
and IPv6 is not enabled.I'm going to try Google DNS next but it's confusing as to why it should make a difference. I want to understand what the RAX20 is doing differently that DNS lookup would be impacted
- plemansOct 21, 2021Guru - Experienced User
We've seen multiple product lines with dns issues. We've also seen windows defaulting to looking up ipv6 addresses first. Thats why sometimes it works if you refresh a time or two.
so both options are worth trying out.
- plemansJan 24, 2022Guru - Experienced User
Did you both try the IPv6 option?
