hwanjongyu
Mar 22, 2022Tutor
RAX20 - It has power issue
I bought RAX20 last August and works as expected. I found there was update yesterday and updated it. Right after updating, it was working. But this morning I found that WIFI was not connected and ...
Mar 22, 2022Guru - Experienced User
If you bought it in august it should be in warranty.
I'd try a different outlet as well.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
