hwanjongyu
Mar 22, 2022Tutor
RAX20 - It has power issue
I bought RAX20 last August and works as expected. I found there was update yesterday and updated it. Right after updating, it was working. But this morning I found that WIFI was not connected and ...
Anonymous
Mar 24, 2022To turn the power on and off on my RAX20 you have to press and hold the button in for a couple of seconds before it does anything.
If you just single tap/press the button it doesn't do anything, though i'm guessing it can't be that if it was working and then suddenly powered off.
hwanjongyu
Mar 24, 2022Tutor
I tried to press power button more than 1 minute but nothing happens.
I also checked power adapter with other device and it is not adapter issue.
I submit support for this two days ago but status is not changing for two days.
I don't think Netgear didn't check support page.
Do I need to make phone call for this?
Please let me know.
- plemansMar 24, 2022Guru - Experienced User
Go through the support site and call the number through that.
- hwanjongyuMar 24, 2022Tutor
Yes, I did this morning and got RMA confirmation.
Thanks.
