Rev0lution
Jun 06, 2020Aspirant
RAX20 - Just turned on new router and not getting full speeds from ISP
RAX20 | AX1800 | Firmware Version V1.0.1.58_2.0.31 I was having problems with my Linksys router and my ISP says they don't play nice with Linksys anyway so I'd like to switch to Netgear. I ca...
- Jun 07, 2020
So I opened up a support case for this. We were able to get the full 500Mbps by downgrading the firmware by one version. Steps:
>> Open a web browser on a device which is connected with router and enter the URL: support.netgear.com
>> Please type in your router's model number and hit enter
>>Click on DOWNLOADS
>>Download a previous version
>>Unzip the file if required
>>Open a new tab and enter the URL: www.routerlogin.net
>>If the page asks you to log in, the username is admin (lower case). Password is the one that you might have created during the initial setup of the router
If it does not accept the password then the default password is the password(lower case).
>>Once you are logged in, at the top, there is BASIC and ADVANCED, click ADVANCED.
>> On the left side there are few tabs, click ADMINISTRATION then click ROUTER/ FIRMWARE UPDATE.
>>Upload the file that we just downloaded
>> Once the firmware is updated, the router may reboot. If it doesn't reboot then turn off the router and turn it back on after 10 seconds.
Rev0lution
Jun 07, 2020Aspirant
>>Click on DOWNLOADS
Christian_R
Jun 10, 2020NETGEAR Employee Retired
Hello Rev0lution,
Thanks for sharing your experience! It may help others who may experience the same issue.
Christian
