RomeoVictor
Dec 11, 2021Follower
RAX20 - speed LAN port
Hello My configuration is pretty standard : box provider + Netgear rooter. The only thing is that I disabled the WIFI from the box to use RAX20 as WIFI rooter. My point is about the download spe...
Dec 11, 2021Guru - Experienced User
Have you tried replacing the cable between the modem/gateway and the router?
Have you logged into the router and checked its wan connection stats to see what speed its connecting at?
Take a screen snip of post it back here.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
