Retired_Member's avatar
Retired_Member
Mar 26, 2021
RAX20 - unable to setup router as wireless repeater
I bought an RAX20 AX1800  Wifi-6 router. I am unable to configure the router as a wifi repeater. I have an existing WiFi router and want to extend it wirelessly using this router. However, the only s...
  • plemans's avatar
    Mar 26, 2021
    You're correct. It doesn't have a wireless repeater mode.
    No where in its specifications does it advertise as such.
    You could look into returning it and getting a wireless extender or you could look at finding a way to hardwire it in and use it as an access point
