Dmakepiece
Mar 22, 2022Tutor
RAX20 - won't connect via cable modem
Just got a RAX20 router, and tried to connect it to my Virgin Media (UK) hub set in modem mode. Have successfully set the Hub to modem mode; powered it up; powered up RAX20; connected Hub to WAN port...
- Mar 29, 2022
For the benefit of anyone else who polls up here with a similar problem, I did eventually try a combination of leaving the Hub for 10+ minutes to stabilise before switching on the router (as recommended), then skipped the wizard, set up a new admin password, THEN returned to the wizard to get it talking to the modem. Finally worked.
Mar 22, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Contact the ISP for additional help and information regarding there modem and configurations.
Dmakepiece
Mar 23, 2022Tutor
Hi - thanks for the reply. Yes I did try with that exact sequence (following another post) but no go.
