Dmakepiece
Mar 22, 2022Tutor
RAX20 - won't connect via cable modem
Just got a RAX20 router, and tried to connect it to my Virgin Media (UK) hub set in modem mode. Have successfully set the Hub to modem mode; powered it up; powered up RAX20; connected Hub to WAN port...
- Mar 29, 2022
For the benefit of anyone else who polls up here with a similar problem, I did eventually try a combination of leaving the Hub for 10+ minutes to stabilise before switching on the router (as recommended), then skipped the wizard, set up a new admin password, THEN returned to the wizard to get it talking to the modem. Finally worked.
Mar 22, 2022Guru - Experienced User
I see a lot of issues with the virgin hubs and their passthrough/modem only mode.
Tends to be sketchy and not work properly.
What a lot of people do is leave the virgin hub in router mode (disable its wireless) and then put the netgears IP address into the virgin's DMZ.
Dmakepiece
Mar 23, 2022Tutor
Why am I not surprised to hear the Virgin Hub is flaky...? Good advice, which I'll probably end up following, but irritating to have to accept a compromise.
