Dmakepiece's avatar
Mar 22, 2022
RAX20 - won't connect via cable modem
Just got a RAX20 router, and tried to connect it to my Virgin Media (UK) hub set in modem mode. Have successfully set the Hub to modem mode; powered it up; powered up RAX20; connected Hub to WAN port...
  • Dmakepiece's avatar
    Dmakepiece
    Mar 29, 2022
    For the benefit of anyone else who polls up here with a similar problem, I did eventually try a combination of leaving the Hub for 10+ minutes to stabilise before switching on the router (as recommended), then skipped the wizard, set up a new admin password, THEN returned to the wizard to get it talking to the modem. Finally worked.
