Dmakepiece
Mar 22, 2022Tutor
RAX20 - won't connect via cable modem
Just got a RAX20 router, and tried to connect it to my Virgin Media (UK) hub set in modem mode. Have successfully set the Hub to modem mode; powered it up; powered up RAX20; connected Hub to WAN port...
- Mar 29, 2022
For the benefit of anyone else who polls up here with a similar problem, I did eventually try a combination of leaving the Hub for 10+ minutes to stabilise before switching on the router (as recommended), then skipped the wizard, set up a new admin password, THEN returned to the wizard to get it talking to the modem. Finally worked.
Dmakepiece
Mar 29, 2022Tutor
Mar 29, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
