microsvc2
Jan 30, 2021Tutor
RAX20 / AX1800 Firmware readySHARE bug?
I have upgraded the firmware on my RAX20 to V1.0.2.82_2.0.52 and it is working EXCEPT that the readySHARE USB LED is not on on ther front of the router. I can access readySHARE as before but the LED...
Christian_R
Feb 04, 2021NETGEAR Employee Retired
Hello microsvc2,
May you factory reset your router and let us know if your issue persists.
Christian
microsvc2
Feb 04, 2021Tutor
I assume I will lose all my changes, is it OK to export my config and import it after reset?
