microsvc2
Jan 30, 2021Tutor
RAX20 / AX1800 Firmware readySHARE bug?
I have upgraded the firmware on my RAX20 to V1.0.2.82_2.0.52 and it is working EXCEPT that the readySHARE USB LED is not on on ther front of the router. I can access readySHARE as before but the LED...
Retired_Member
Mar 31, 2021Hi microsvc2,
I recently purchased the Netgear RAX20 router, and faced the same issue as yours after upgrading the firmware to V1.0.2.82_2.0.52. I wanted to know if your issue has been resolved and if yes, then how?
Thankyou.
microsvc2
Mar 31, 2021Tutor
No, this is not resolved. I spoke directly with an engineer in Tiawan (I think) and he said this should be fixed in the next firmware release. I just went back to my previous release for now and am watching for a release higher than 82. It's been months already. Apparently not a priority.
- 8tailsCATApr 26, 2021Initiate
I also encountered this problem, the ReadyShare function is normal, but the USB light is not on. When the next firmware update will be release? It is already 3 months passed. Waiting for it
