Retired_Member
Jan 11, 2022Rax20 and IPv6 from my ISP
Hello! As I can't add the model under the threads topic: RAX20, Firmware Version V1.0.4.100_2.0.64 The problem is following: I tried to turn on ipv6 on auto detect and auto config, but neither ...
Jan 11, 2022Guru - Experienced User
What modem/gateway is the router connected to?
- Retired_MemberJan 11, 2022
None, I have an ONT in my apartment and a CAT6 cable from the ONT to the RAX, ipv6 worked with an older tplink and ddwrt, but rax20 cant seem to automatically work with it.
- plemansJan 11, 2022Guru - Experienced User
when you had the tp-link connected, were you able to check what the ipv6 settings were?
