alpnet17
Jun 05, 2021Initiate
RAX20 authentication problem
I have Netgear model # RAX20. My cell phone (Android) cannot connect to Netgear WiFi. I get this message: "Authentication Problem" . How can I connect my cell phone to Netgear WiFi?
- Jun 05, 2021
did you put in the password wrong?
Try deleting the network from your phone and re-connecting it.
Jun 05, 2021Guru - Experienced User
siliconglen
Jun 06, 2021Tutor
Didn't work for me.
Changed the password, same error
Made the network open, got "can't connect"
Then went back to password protected and went back to the error
- plemansJun 06, 2021Guru - Experienced User
Is it only 1 device with the issue?
Are you using any special characters in the ssid/password?
- siliconglenJun 09, 2021Tutor
It's happening on multiple devices.
No characters outside of A-Z, a-z, 0-9
