64sportscoupe
Dec 22, 2020Aspirant
RAX20 (AX1800) nighthawk daily dropouts
My Nighthawk AX1800 (RAX20) WiFi 6 router disconnects all wifi EVERY. SINGLE. DAY. It’s killing me. Connected devices are; 5 IOT devices (lights), 2 MacBooks, 1 Laptop PC, 3 iPhones, 1 galaxy, 2...
Dec 22, 2020Guru - Experienced User
What firmware version are you on?
What modem/gateway is it connected to?
64sportscoupe
Dec 23, 2020Aspirant
Gateway is the Australian NBN FTTC NCD, same as everyone else.
Firmware is V1.0.2.64_2.0.42
- plemansDec 23, 2020Guru - Experienced User
64sportscoupe wrote:
Gateway is the Australian NBN FTTC NCD, same as everyone else.NBN=national broadband network.
FTTC=fibre to the curb
NCD=network connection device
Basically all you told me is you have australian internet and its fibre. And everyone in australia has it according to your "same as everyone else".
That's not a gateway. It doesn't tell me if its just an ONT or a gateway with integrated router.
- 64sportscoupeDec 23, 2020AspirantI have no idea what those things are. I connect the nighthawk to the NCD via an Ethernet cable and it has internet. That’s the entirety of my internet infrastructure in my home.
- dropsznDec 29, 2020Initiate
Have you had any luck resolving this? I have similar symptoms, with the RAX20 dropping one device at a time, both ethernet and wifi, requiring reboots multiple times a week in order to allow the devices to reconnect.
I was told that NetGear was escalating my case and that I'd hear back in 1-2 days, but it's now been four weeks and I'm not sure what to do next.
