turnerdon
Sep 13, 2020Aspirant
RAX20 Blocking specific Site
My Nighthawk RAX20 blocks one site I've eleminated it being a website, hosting, ISP or computer problem. It all points back to my router. The error message is ERR_CONNECTION_REFUSED I've done...
- Sep 15, 2020
So much for that fix.
It worked for a short time and the problem is back.
Netgear support is not responsive.
My only solution to have a reliable router is to dump the Netgear router and go back to ASUS routers.
Netgear, you can close this post. I'm off to buy a reliable router.
turnerdon
Sep 14, 2020Aspirant
UPDATE !!!
Seen several suggestions to spoof the MAC address. This worked.
I would like thank the guy named Babylon ** but I can't find the article I seen the suggestion on.
All fixed, thanks again
- turnerdonSep 15, 2020Aspirant
- rinthosSep 15, 2020Luminary
turnerdon wrote:So much for that fix.
Assuming the site is legit...can you share the URL?
